Is there any VFW codec or an easy way to play any MXF file coming from Panasonic P2 recording?
I know each MXF has just video content wrapped inside a MXF container, but would be very useful a quick view of each file without the need to call Premiere or any other NLE software.
I know there is something called 'P2viewer' but I found it not so useful.
Is there any subversion FFMPEG which could handle those files?
Any suggestion?
Thank you in advance.
the video is dvcpro hd at 50Mbps, not easy for anything to play.
P2 flash cards can contain DV, DVC-Pro25, DVC-Pro50 or DVC-ProHD video files.
VLC will play DVC-Pro but I'm not sure whether it works with an MXF wrapper.
Same goes for DVMP an $80 player (free demo).
http://www.dvmp.co.uk/
A handy utility for conversion of P2 media is the $179 Firestore DV file converter for P2.
http://www.bhphotovideo.com/c/product/422301-REG/Panasonic_DVFILEPRO_FireStore_DV_File...Converter.htmlLast edited by edDV; 24th Aug 2010 at 11:02.
http://www.kiva.org/about
MXF XDCAM HD 422 loses stereophony?
By elmuz in forum Video ConversionReplies: 0Last Post: 2nd May 2011, 06:29 -
.mxf and avid troubles
By pjcom in forum Capturing and VCRReplies: 0Last Post: 31st May 2010, 22:14 -
Mp4 and MXF footage trouble in FCP
By jcooper85 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2008, 12:15 -
DV-DIF as used in Panasonic P2 + MXF
By themoog in forum Video ConversionReplies: 0Last Post: 18th Mar 2008, 14:56 -
Any player that will play MXF file or MP4 wrapped file
By ljCharlie in forum Newbie / General discussionsReplies: 0Last Post: 25th Feb 2008, 08:58
