I recently shot miniDV video of a relatives wedding and in the process of 'capturing' it to DVD, while monitoring the video during transfer, I noticed severe blocking. Is this a playback issue with the tape head or a recording issue? Can it be cleaned up? The majority of the footage was indoor, low-light (reception) Capture is being done as pass-through thru the camera (Canon ZR-70), A/V line out (1/8" jack) to RCA inputs on the DVDR.
Would I have better results using firewire or usb from the camera directly to my computer?
Thanks in advance
Normally you capture as DV using WINDV or similar to copy the video losslessly then encoding with a software mpeg-2 encoder. This needs a computer. It looks like you are feeding the analog output of the camera into a dvd recorder. At the very least attempt to use the s-video output and see if it looks better. If your dvd recorder has a firewire connection you might use that.
If it's a DV camera you should use Firewire. Then you get the actual digital info from the tape as-is.
Need help dealing with blocking
By drawar in forum Video ConversionReplies: 4Last Post: 15th Jun 2011, 04:04 -
Something is Blocking my Firewire
By tomer621 in forum Capturing and VCRReplies: 0Last Post: 5th Dec 2010, 04:14 -
Is this macro-blocking?
By txporter in forum RestorationReplies: 12Last Post: 15th Mar 2010, 06:07 -
"fixed" AVI has audio sync and video blocking problems
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 05:00 -
New Blocking Signal from Dish?
By spire in forum Newbie / General discussionsReplies: 18Last Post: 27th Dec 2007, 00:42
