Hello,
I have an LG RH387H DVD player and I want to make it region free, currently it's region 2. I have tried the following but it doesn't seem to work, after pressing 0 seven times there is no window indicating it's region free. This is what I tried:
Region code hack posted by juanseeker, February 17 2010:
1. Press "HOME"
2. Select "EASY MENU" "SETUP"
3. Scroll to the LOCK symbol
4. Press "0" seven times
5. You will see a window indicating you are Region Code Free "YES"
6. Press "ENTER"
7. Press "RETURN" to exit out and complete.
I also tried:
4 user region code/hacksFebruary 17, 2010Post region code/hack comment
Region code hack posted by slingvar, December 30 2008:
Go to this link: http://hk.lge.com/support/support_lgeservice.jsp
and click on 'Product Support' a new window will open,
click on 'Device Driver' in the menu at the left side.
click on 'DVD Player/Recorder' under Product and roll down to 'Software Update for RH3xx series' and click
on 'RH3xx.iso' choose SAVE. Save it on place where you will easy find it.
After clicking on DVD Player Recorder I did not see anywhere to download a software update for RH3xx series.
Can anyone help?
Chris
