How could I encode a LPCM 5.1 audio track to DTS 5.1 ??
What softs are necesary ??
Results 1 to 9 of 9
OR...
DTS-HD Master Audio Suite Encoder
( a.k.a. "DTS-HD Monster Audio Suite Encoder"
It has two advantages (apart from the absurd price, of course):
--- it's NOT only for "Blu-Ray content" ;
--- it does let you use other bitrates than 1509kbps and 754kbps . -
@El Heggunte
Can I use Nuendo for splitting LPCM files into tracks ??? this operation must be done before using DTS-HD Master ASE , I presume... -
@poisondeathray
I abhor this eac3to because it needs an interface or additional softs to get what you want... -
not with lpcm , you don't need any additional software (lpcm is already uncompressed, you don't need any special decoders like arcsoft etc...)
you just type 1 line:
eac3to input.lpcm output.wavs
you can try audacity beta as well. file=>export multiple . You might have to setup the ffmpeg decoding options in the setupLast edited by poisondeathray; 24th Jun 2010 at 13:28.
@greymalkin
Extract audio from dvd-a using dvda explorer as wavs then go to surroundbyus and get theyr software--it can do mkv audio only,dvd audio only or avchd disc [i think],wich is compatible with most bd players.
Anyway your solution is to obtain a avchd disc!
M
lpcm to dts/ac3
By bigman1992 in forum AudioReplies: 9Last Post: 8th Dec 2010, 02:48 -
Converting LPCM , DTS and AC3
By Benjy in forum AudioReplies: 10Last Post: 8th May 2010, 06:20 -
DTS-HD/MA to LPCM
By scub in forum Video ConversionReplies: 0Last Post: 27th Apr 2010, 18:39 -
Problem converting DTS-HD to LPCM
By seplant in forum Blu-ray RippingReplies: 4Last Post: 3rd Mar 2010, 21:06 -
DTS-HD to LPCM and PS3 - How I Did It
By decker12 in forum Blu-ray RippingReplies: 11Last Post: 25th Aug 2009, 19:04
