  1. Hi,
    I honestly wasn't sure where the best place was to post this--but if this isn't it, hopefully you can point me in the right direction.
    I'm in the market for a DVD recorder; it's going to be used mainly to dub DVDs from PAL to NTSC (I have a region-free player it'll be connected to). What I can't figure out, though, is whether the recorder itself needs to be region-free (or whether such a thing even exists). I know that the recorder that I am replacing had to be switched between PAL and NTSC mode, depending on the signal coming from the player.
    So, when shopping for a DVD recorder, can I buy any old recorder--or does it have to be somehow multi-region?
    Thanks!!
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Multi region - region free only applies to playback. All recorded DVDs are region free.
  3. Why are you converting from pal to ntsc?
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  4. thanks, but my question is not about the physical dvd being burned--it's about whether the recorder will be able to read either PAL or NTSC input? is that a consideration?
    thanks!
    You're confusing some things.
    Read this: http://www.digitalFAQ.com/forum/showthread.php/uk-dvds-regions-1948.html
    Video formats and DVD regions are two separate concepts.
