Hello,
My grandson was playing with my dvd player and somehow switched the pal/ntsc on the region code section of the menue. Now my TV does not recognize my player. I cannot access the set up on the dvd or get a picture from it to change it back. It is a Sungate dvd 2026. Any help on this is appreciated.
Thank you
Results 1 to 10 of 10
Region Codes and NTSC/PAL have nothing to do with each other.
Did your grandson try to "hack" the machine to make it "region free"? -
Evedn if it has been changed from ntsc to pal you would still get a picture on the tv, it would probably be rolling though, the picture that is not the TV
Unplug the dvd player, while you check the cables are all connected as they should as your grandson may have played with those.
Plug the dvd player back in and see what happens.
I had to fix one once by blindly using the remote and instructions from the manual to change it, either that or get it to a multi system tvPAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
He was in the menu items. clicked on the pal on the list and hit enter. The screen went blank and the TV says (Does not recognize component)
I was brought up that if I broke it I fixed it
Ok, so, I hooked it up to an older TV and the screen rolls. It rolls so much that I can't see the menu. Any idea's? There is nothing wrong with the sound.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC Picture Quality?
By Mike99 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 13th Aug 2010, 05:28 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
PAL to NTSC renders OK on top of picture, flickers on bottom half
By Exiled_Brit in forum Video ConversionReplies: 6Last Post: 21st Sep 2008, 15:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
