hi all
I have been copying stuff from video tape to dvd-r, used Mpg2cut2 to divide them into individual files eg commercials and then uploading them to Youtube and they are fine for videotape quality. But i find any file over a couple of minutes after uploading & processing, the audio is then out of sync, the only theory i have for this is maybe because i am using PAL video & youtube is converting it to NTSC?
Anyway then i have converted some longer files to MPEG4 with SUPER & uploading them because thats one of the file types they recommend & they seem to turn out fine, which is great but if they are files over a few 100 mb then its pretty slow on my old 1.6ghz Sempron with 512mb rameg tried a 700mb file & quit after
30mins because it had only done about 20% of it.
Any ideas on what other programs i could use to do this that would be faster on my old pc? without degrading quality too much, as i said its only video tape but i want it to still be pretty clear picture.
cheers from Oz![]()
Your original VHS files would be luck to have 400 lines of resolution with as many pixels to start with. The DVD standard (PAL) is 720 x 575. So you really can't use that resolution and it would be slowing down your upload unless you dumped it in Super.
I'd suggest using wmv at 320 x 240 (which was YouTubes original resolution (flash) before HQ and HD).
I know Youtube recommends H.264 -- but that's because it streams H.264 in an FLV container for HD.
Trying to convert my vob files for upload to youtube.
By Aly199 in forum DVD RippingReplies: 9Last Post: 20th Jul 2015, 04:57 -
convert video to upload to youtube
By ktnwin in forum Video ConversionReplies: 5Last Post: 1st Mar 2011, 17:11 -
Help convert Mp3 so i can upload it on youtube ^__^
By Jenniilovekpop in forum AudioReplies: 10Last Post: 30th Nov 2010, 17:06 -
Easiest, fastest way to convert MKV to Blu Ray with 1080p aspect ratio
By jfk8680 in forum Authoring (Blu-ray)Replies: 3Last Post: 12th Apr 2010, 23:07 -
Upload videos to a site, automatic convert to FLV (just like youtube)
By lordsmurf in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2007, 15:07
