Hi, as a newbie i'm almost embarrassed to post this because i've been doing my research in order to find the best free or gnu license (or similar) software that will fulfil my basic editing needs, with the "rubbish" i have filmed, which are:
- A program that works with MP4 files. I don't wish to have to convert them to another file format;
- Allows to insert narrations and texts, as well as subtitles. And songs. And basic sound effects too;
- Let me be free to save the file in the same resolution i have filmed them, or any other i want. Windows Live Movie Maker doesn't seem to aloud me to do so.
Yes, i have searched this forum obsessively to find the best software for this, but yet i don't know if VideoPad will have all of it's functionalities working after a period of time with the free version. After all, it' not open source, is it?
And i don't know if AVI Demux will work with MP4 files and if it can insert narrations and stuff.
Please, help me with these "simple" questions!
Thank you in advance!!!
Results 1 to 11 of 11
You might be able to use mp4cam2avi and then use simple editors like windows movie maker.
Or else try videostudio pro, Vegas Movie Studio, Magix Movie Edit Pro. -
videostudio pro, vegas and magix are all paid, right?
I just uninstalled avidemux LOL
It wasn't being able to save what i had edited (the most basic thing to be done, to cut the movie) so i got over with it. Avidemux was telling me it couldn't handle something with the audio, which i don't get it cause the clip i was working on had only the audio the camera had captured.
Yes, i mean voiceover, sorry. Voiceover with also a soundtrack in the background would be perfect.
Well, so i'd have to download audacity (which is a good program) and do what with the audio file? Sorry, i have never edited before. -
http://manual.audacityteam.org/index.php?title=Mixing
Then save back in whatever format you need.
Of course, with Audacity you only work with audio, you can't see the video at the same time. -
You could use cutassistant to edit (on keyframes) without recoding. You would need to install the programs needed to use cutassistant (asfbin, avidemux, mp4box and virtualdub).
You could then use Yamb or My MP4Box GUI to join and add extras. You could also use mkvmerge if you wanted to use mkv container instead of mp4.
Edit MKV files with a freeware video editing software?
By RaptorZX3 in forum Newbie / General discussionsReplies: 10Last Post: 19th Jun 2013, 03:55 -
Software for Editing MP4 video?
By majax79 in forum EditingReplies: 5Last Post: 1st Aug 2010, 00:52 -
1080p mp4, why bother with all kind of software for editing?
By Phoebos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 11th Jun 2010, 18:31 -
AVI to mp4 Freeware and VOB to mp4 Freeware
By saucedmike in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 01:44 -
Freeware that will take a mp4 and do a one button color restoration?
By andersonmilltexas in forum Newbie / General discussionsReplies: 15Last Post: 21st Dec 2007, 21:46
