Does XVID4PSP work with hyper threading? anyone with an i7 care to comment? I was considering buying an i7 but am not sure if i should if it doesn't as this is a major factor for me. Not just xvid4psp but other programs editing images that are heavy on the cpu etc. What about that 980x. will a 6 core processor be fully used by xvid4psp?
AFAIK, Hyperthreading is OS dependent and not program dependent. It's also an Intel terminology, but AMD may have similar. The i7 and most all newer Intel CPUs have it. http://en.wikipedia.org/wiki/Hyper-threading
Some codecs can make use of multiple cores for faster processing, but that's codec dependent, not the program using the codec. Xvid can be set for six core use and it does show all six cores operating in my AMD six core CPU during an encode, but at only about 30% usage. Divx can use multiple cores also. H.264 can definitely do it as it shows 100% usage on all six cores during encoding. -
nice. I was looking forward to using this cpu with h.264/ Thank you very much.
Extra fan for Hyper 212 EVO
By Stealth3si in forum ComputerReplies: 13Last Post: 25th Mar 2012, 11:01 -
Xvid4PSP - Help
By Simmons in forum Video ConversionReplies: 11Last Post: 30th Mar 2011, 04:09 -
i7-920 Hyper-threading
By wulf109 in forum ComputerReplies: 14Last Post: 8th Apr 2009, 20:25 -
How to use Hyper Terminal in TCP/IP(winsock) mode to communicate ?
By SingSing in forum ComputerReplies: 14Last Post: 31st Aug 2008, 07:37 -
Hyper Media Centre Advice
By greer1988 in forum Media Center PC / MediaCentersReplies: 1Last Post: 8th May 2008, 06:14
