    Dec 2001
    hey,
    I just downloaded a screener of the lord of the rings movie, very sweet....my problem is that when i burned it to a cd i found that everytime i tried to copy the movie back from the disk to the comp or to burn the disk staright to another disk it wouldnt work and i an error that said there was some redundency error or something. So i though that the movie was either locked in some way or something, cause i mean there has to be a way to make more copies of it....any suggestions would be sweet
  2. get cdmate works everytime that's what i use to copy mine with actually it's advertise on this page try it.
    cowboy
  3. clonecd works good for most everything. if i can't get it 2 copy something i use blind write. never had something blindwrite couldn't handle.
  4. Prassi is another good'n as well.
    Just do a straight cd-cd copy.
    Feb 2002
    Brisbane
    I've had a cyclic redundancy error when trying to read a cd because the cd was stuffed up (the plastic cover melted on the disc)
