Hiya guys just wondering what you guys thought the best avi to dvd software is out there right now with the best conversion quality??? I've been using tmpgenc over the years, just wondering if there is anything better out there???
It depends on what you want to get out of it and what features you need.
If you want fast, reliable and reasonable quality, ConvertXtoDVD (version 3 preferred). The menu templates are OK, and the rest of the features are good for the price.
If you want higher quality and are prepared to wait, then I would recommend AVStoDVD. It has basic menu tools, but a high quality encoder (HCEnc), allows you to modify the avisynth scripts it uses, and has the ability to output elementary or programme streams if you prefer to author in a different tool. It also batches jobs, which is handy. AVStoDVD is free, and well supported. The author is regularly releasing updates and improvements, and frequents these forums supporting his users.Read my blog here.
To keep things simple use avstodvd like gunslinger suggested. If you want more control over the whole process then use some basic avisynth scripts with hcenc for your video, do your audio with avisynth and wavi, then author with what ever authoring software you prefer (guifordvdauthor is a good free one).
Donadagohvi (Cherokee for "Until we meet again")
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
