So I have a set routine on how to convert flvs. They come from skate.reel and are vp6/adpcm. Now I'd extract the video with flvextract (no audio since it doesn't support adpcm), then load that avi via directshowsource in avisynth with the flv used for sound. I do it this way because it otherwise desyncs. AVS would look something like this:
v = directshowsource("video.avi")
v = v.assumefps(30)
a = directshowsource("video.flv")
a = a.resampleaudio(44100)
clip = audiodub(v, a)
return clip
I'd then send that to x264 and use vdub to extract the audio. Use mp4box to wrap it all. FFDShow (ffdshow alpha techinically) makes the magic happen really by having everything set up right. One of the other reasons I do it like this is because I use quite a few avisynth functions to edit the videos together and it let's me easily automate everything while keeping the quality up.
Now recently I needed the audio to be AAC and trying to find a way to do it, I checked out SUPER. Since it can load AVS and spit out AAC.
Now everything is broken.
I'd only just done a conversion before I installed SUPER. Once I had installed SUPER, the piece of shit broke everything. I can no longer use my old method and I can't use SUPER either (it outputs a video with the error message).
This is the error message:
DirectShowSource: Could not open as video or audio.
Video returned: "DirectShowSource: couldn't open the file video.flv: Class not registered"
Audio returned: "DirectShowSource: couldn't open the file video.flv: Class not registered"
I tried uninstalling SUPER and FFDShow, even avisynth and reinstalling it all, but apparently that isn't good enough, whatever SUPER has done has fucked shit up well proper. So my suspicion is that SUPER has dropped some altered DLLs that it leaves behind, possibly write protected, or change some sort of direct show association. I remember one time long ago I registered and deregistered some stuff, but I can't recall and google didn't turn up anything either.
FFDShow is still configured correctly, even after the reinstall, but nothing. I'm really frustrated right now, so any and all help would be appreciated. One to fix this issue and get FFDShow and AviSynth working properly while ridding myself of the SUPER cancer and getting something that can either do avs to aac or wav/mp3 to aac.
Much obliged.
				Results 1 to 9 of 9
	If something looks like shit and smells shit so it must be a shit!  The sad news is SmUPER is still recommended by users in this forum The sad news is SmUPER is still recommended by users in this forum
	Well, I went with it cause it could've gone AVS->AAC, but the FLVSplitter issue prevented that. Well it couldn't in the end and after a bit of google I found FAAC at http://www.rarewares.org/aac-encoders.php
 Which is cli and even better for automation.
	TO WHOM IT MAY CONCERN AND TO WHOM IS CONCERNED ABOUT LAST SUPERC UPDATE
 Since Supforum is down, I report here the following bug with
 SUPER © v2010.build.42 (Nov 7, 2010)
 Any video file (up to 1080p) with H264 codec plays fine on my computer with BSplayer and CoreAVC Version 2.0.0.0 (Updated on 2009-12-18).
 Unfortunately, if I install the above SUPER © on my computer and run the program once, then the video files won't play properly any more (the image shows some decompression problem) even after closing SUPER C.
 I have to reinstall CoreAVC to play the video correctly again.
 I do not like the fact that SUPERC does not uninstall properly and hide some curious files or update onto the HDD
 happy new year
 Excuse my English cause I am a French Frog!
	right hech54...I never had this problem either with 2010v38. Unortunately, as mentionned extensively, it is impossible to go back to working earlier version once update installed...So I have to get rid of Super C all together cause I will not reinstall OS from scratch just for that! Now I am looking for an alternate to SUPER C with the same versatility...Thanks for any advise hech54 Last edited by jeromepadoue; 6th Jan 2011 at 11:50.
  New pc broke already???By capman21 in forum ComputerReplies: 2Last Post: 30th Mar 2010, 11:13
  What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05
  Windows Updates broke my PGCEdit?By TooLFooL in forum Newbie / General discussionsReplies: 9Last Post: 27th May 2009, 01:25
  TV broke down!!By SnoopNL in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Feb 2008, 12:37
  JVC DR-MH30 Broke I Think Update.By hutch642 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Dec 2007, 09:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
