Computer and monitor have been humming along for a couple years now, but over the past month, on a few occasions what has happened is:
CPU seems to go into sleep mode all by itself -- the monitor goes black, CPU power stays on, all HD activity ceases. Sorta like when the monitor goes to sleep, and all you need to do is hit any key to bring the monitor to life again -- only when this happens the monitor stays dead.
It only happened a few times during the past month, until this weekend, when it's now happening several times a day.
Are I overheating? (The weather has turned hot here in NYC.) Is it the power supply?
I'm running Panda Cloud 24/7, and have done a full scan with Cloud, with Malware Bytes, and with Super Anti-Spyware. Nothing bad found.
Thank you!
1: Shut it down , remove power cord, remove side panel and remove dust biuld up.
What you describe is likely to be a few things by this stage.
1: Monitor stays dead = faulty gpu
2: Powering off = psu defect
After dust removal I would invest in silver artic 5 and replace the heat grease compound on your cpu, if it is over heating it can trigger these power of symptoms.
Retest then move onto testing gpu and psu for possible faults -
Thank you, BJS. Will do.
Just tried SpeedFan and the GPU at the moment is coming in at 89 degrees C. Yikes! -
Wow, you can bake some biscuits inside your computer case. Yep, better take Bjs' advice.
You bet, filmboss. Thanks.
SpeedFan also just told me that 1 of my 3 fans is dead. Guess we found the problem.
Having Strange Problem with after encode!
By Jimbo1 in forum Video ConversionReplies: 1Last Post: 20th Mar 2011, 04:36 -
Strange Audio Problem
By Wanderlustus in forum ComputerReplies: 4Last Post: 21st Feb 2011, 14:27 -
I have a strange problem and I would like to ask if is possible to be solve
By takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 14:53 -
Strange PSU problem
By mysts in forum ComputerReplies: 9Last Post: 20th Jun 2009, 12:12 -
Strange Problem with MP4Box
By belatu in forum Video ConversionReplies: 4Last Post: 18th Jun 2009, 10:09
