Hi I have been out of video editing for a heck of along time (2003-2005) so I am almost back to square one or two. The last video editors I have on my computer are Video Studio 10 & also 11, then there's the Windows XP Movie Maker (comes installed together), and I have an old copy of Adobe Premiere Pro 1.5 from back in 2005 but I never installed it.
Bought my FujiFilm S2000HD camera about a year ago, it takes HD movies in .mp4 mode, not even sure what the details are. I have to use a video transfer program to change the movies into .avi mode or the like but I'd rather just find a movie editor that can directly handle the movie files straight from the camera. Video Studio 10 and 11 make the movies look blurry and much smaller than they are.
My apologies if there is a thread on this before, if so please kindly direct me there. I looked in the tools section of the homepage but I couldn't find exactly what I'm looking for. The only program that did what I want is called "AviDemux" but it doesn't offer text on the screen (like titles) and some other neat graphic transitions like the above movie makers do. Thanks for any advice.
First use mediainfo to identify the codec used. mp4 and avi are containers.
Fujifilm isn't clear in the specs whic codec is used
" 1,280 x 720 pixels [HD] (Max individual recording time: 15 min.) / 640 x 480 pixels / 320 x 240 pixels (30 frames/sec.) with monaural sound, with Electronic Image Stabilization "Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Acording to dpreview, The codec is MJPG (motion JPeg).
http://www.dpreview.com/news/0808/08081201fujifilms2000hd.asp
You will need an MJPG codec installed for Premiere or Virtualdub to see it. Some free programs have the codec internal. AVIdemux would be one of those.Recommends: Kiva.org - Loans that change lives.
Thanks for helping me do some homework. I was wondering what the details are and was looking for one of those "id" programs. I ran the mediainfo program and it gave me the following results. I notice that it says in there "h.263" but I thought it was perhaps was supposed to be "H.264", don't know if that makes a difference. Yes, that AviDemux program seems to process the video fine, but it didn't offer additional features like adding in text titles and some graphic effects. You mentioned VirtualDub, does that offer text and titles? Here's the specs that mediainfo gave me:
General
Complete name : H:\DCIM\130_FUJI\DSCF0490.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 10.4 MiB
Duration : 9s 476ms
Overall bit rate : 9 212 Kbps
Movie name/More : FUJIFILM DIGITAL CAMERA
Encoded date : UTC 2010-06-14 18:08:45
Tagged date : UTC 2010-06-14 18:08:45
Origin : Digital Camera
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L3
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 9s 476ms
Bit rate mode : Variable
Bit rate : 9 000 Kbps
Maximum bit rate : 18.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.326
Stream size : 10.0 MiB (96%)
Language : English
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Format settings, PS : Yes
Codec ID : 40
Duration : 9s 472ms
Bit rate : 128 Kbps
Maximum bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 147 KiB (1%)
Language : English
AVCHD editor Sofware with lossless video output,which can handle PSF format
By Stears555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 14th Feb 2012, 04:56 -
Very Basic--> What format to work with Final Cut with my HD cam.
By Mcjuicypants in forum EditingReplies: 0Last Post: 5th Mar 2011, 21:55 -
Fujifilm S2000HD still camera with video
By jbartosh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Sep 2010, 20:52 -
losing audio when loading into vid editor..
By krohm in forum EditingReplies: 26Last Post: 24th May 2010, 09:41 -
Newbie needs help..can't capture video from dig vid cam to computer
By lithnights in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 19:08
