    Aug 2006
    I'm encoding a sporting event i captured (1280x720) with great quality, the only issues i have is that when I try to fast forward to different points in the video it get pixelated for 1 -2 second and gradually goes back to normal quality.
    I tried to download similar videos and they don't have that issue.
    I'm using megui to encode, what's causing this and how do i fix it?
    Here's a pic: http://www.postimage.org/image.php?v=aVTcw29
    Too low bitrate? What bitrate settings are you using?
    Aug 2006
    bit rate is 5606, a 30 sec clip and 20mg
    its only happens when i'm seeking or fast forwarding
  4. What happens when you try another media player, like MPCHC or KMPlayer. VLC sometimes has this problem with AVC streams
    Aug 2006
    it doesn't have that issue on those players, just vlc. but i'm wondering how others who made avc streams not have that issue on their videos. is there a setting on megui and will help with that?
  6. is there a setting on megui and will help with that?
    Nope, it's vlc's fault . It's been very buggy the last few years, it's not recommended software anymore. These are known issues with AVC playback which haven't been fixed
    Aug 2006
    kewl i just downloaded the newest version (1.1.0) and it fixes this problem, now they need to work on there dvd playbacks
    "Improved support for MKV HD, including seeking fixes, and 7.1 channels codecs"
