Hi
I have a avi video clip i'm going to convert to DVD. But the clip has background hiss,white noise,static call it what you will.
What converting software would be best to use to filter sound out or lower it?
Thanks for your time
It would be much better try fix that in a sound editor like audacity, goldwave, adobe audition.
For Audacity, look here: http://audacity.sourceforge.net/help/ Removing hiss or low frequency rumble is mostly a function of the Low/High pass filters. Using either one may remove part of the sound quality also, so it's mostly just trial and error. I'm sure Goldwave has similar tutorials.
With Audacity, you can test with a small part of the audio clip, then if it's not right, just start over with no changes in the original file. The Audacity noise filter is more useful with repetitive noise, like 60Hz hum or similar. It uses a short section of silence from the file to set the filtering level.
Need advice; using Audition to remove hiss (and noise?)...
By takearushfan in forum RestorationReplies: 22Last Post: 4th May 2010, 05:29 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 05:54 -
removing wind noise
By Reggie6966 in forum AudioReplies: 2Last Post: 31st Aug 2008, 12:47 -
removing background noise
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 22:27
