I tried to burn a bd from m2ts files as videoed on a sony camcorder using the free supplied sony PMB software.
Unfortunately when persons are running e.g. footbal games they appear to have up to 5 legs, panning results in any vertical columns appearing as three adjuscent posts. Settings in the software do not seem to give much options. What am i doing wrong?
they have 5 legs when viewed from the camcorder? or burned to BD and viewed on a blu-ray player?
you can try other authoring software e.g. multiavchd which is free and works nicely -
This is the result of a blend deinterlace.
The m2ts files are probably 1440x1080i or 1920x1080i.
Sony Vegas Movie Studio Platinum would allow you to maintain interlace to the BD disk.
As suggested, try free multiavchd first.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thanks for the useful repplies, the multiple legs are only seen on the burned BD, when viewed via hdmi directly from the camcorder they are fine. It is the legs of the players when they are running, as if the coder is not coding correctly.
I will try as you sugest and compare.
Again thanks for the tips.
How do I extract several scenes from multiple DVDs or convert to?
By DVDHelpPlease in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2010, 01:54 -
Multiple instances of an actor in same shot, with moving camera
By wildpozzer in forum Capturing and VCRReplies: 4Last Post: 12th Mar 2010, 02:36 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 07:30 -
I am an idiot - Blurry Images on Fast Cars.......interlace or capture prob?
By coolstuffiniowa in forum Newbie / General discussionsReplies: 5Last Post: 19th Dec 2007, 20:19 -
mp4->xvid video moving too fast
By Snowcrystal in forum Video ConversionReplies: 1Last Post: 28th Jul 2007, 12:50
