Hi!
I am trying to convert an AVI file to MOV using ffmpegx (on my mac). Now, it worked the first time i tried, but when i was trying a second time the finished product in the "progress" window finished like the min i clicked "encode"... The size of the product was zero kb... When i click on the blue "i" in the progress window, this is the message:
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Sun Jun 20 19:40:23 CEST 2010
Input #0, avi, from '/Volumes/My Passport/COMENSE 09-10/VIDEO PARTITE COMENSE/comense-parma/comense-parma.avi':
Duration: 01:45:35.7, start: 0.000000, bitrate: 1105 kb/s
Stream #0.0, 25.00 fps(r): Video: mpeg4, yuv420p, 720x576
Number of stream maps must match number of output streams
Im not a computer wiz and stuff so this is REALLY REALLY complicated for me! LOL...PLEASE help!!!
Sandra
if you can, email me: smjsinclair@gmail.com
ffmpegX only detects one video stream, and no audio stream, while you are converting to a format that specifies two output streams (video and audio). That's why it's giving an error on the number of stream maps.
If your source file really only has video, then de-select "Encode audio" in the Audio tab of ffmpegX, before pressing the Encode button.
Gmail spam filters may be above average, but it's recommended to not publish your e-mail address on (public) forums, to minimize spam.Originally Posted by Sandra
I'm having the same problem and am frustrated after spending HOURS trying to get a simple .mov file encoded to .flv. So if "ffmpegX only detects one video stream, and no audio stream, while you are converting to a format that specifies two output streams (video and audio).... then what do you do if your video has an audio track? If I "de-select "Encode audio" then there will be no sound. Thanks,
I would need more information to be able to suggest a course of action.
- What does the ffmpegX Summary say about the source file (video and audio details)?
- What does QuickTime Player's Movie Inspector (Cmd-I) say about the MOV file?
- And please provide ffmpegX's Process Information log. (You may access the log by clicking the blue "i" in the ffmpegX Progress window after a conversion attempt.)
Hello- I have the same challenge... trying to convert from mov to flv creates empty files immediately. Here is the info from my source:
ffmpegX Process summary:
Encoding started on Mon Aug 9 13:28:46 PDT 2010
Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 12.00 (12/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/billhall/Movies/iShowU HD/DecExampleSimulation.mov':
Duration: 00:09:47.0, start: 0.000000, bitrate: 256 kb/s
Stream #0.0(eng): Audio: aac, 44100 Hz, stereo
Stream #0.1(eng), 12.00 fps(r): Video: mpeg4, yuv420p, 762x511
Codec type mismatch for mapping #0.0 -> #0.0
cmd-i info:
Dimensions: 762x511
Codecs: AAC, MPEG-4 Video
Duration: 9:47
Audio Channels: 2
Total Bit Rate: 229
What am I doing wrong? Any tips?
Thanks!
This issue also came up a while back. Please see post 1718111.
Turn off ffmpegX progress sound after finished conversion
By c.eiermann in forum ffmpegX general discussionReplies: 2Last Post: 2nd Sep 2010, 21:56 -
FLV Metadata(?) problem - ffmpegX Progress hangs at 96%
By ThomasAlbert in forum ffmpegX general discussionReplies: 8Last Post: 1st May 2009, 10:04 -
ffmpegx can't find Progress.app
By jagon in forum ffmpegX general discussionReplies: 5Last Post: 14th Dec 2008, 04:14 -
Problem with Ffmpegx v 009y: can't find progress.app
By cellocgw in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2008, 18:16 -
ffmpegX Progress log
By exekutive in forum ffmpegX general discussionReplies: 5Last Post: 20th Jun 2007, 16:09
