First, I will say I'm slightly confused here. I have several clips in .MTS format that I want to use for some rotoscoping, but before I can do that, I need to convert them to .AVI. VLC says they're 60 (59.940059) FPS, but when I load them into VDub, it says they're 30 FPS. No matter what I convert them to in VDub, the end result is a very jittery video, that stutters and eventually freezes. I've tried using the frame rate conversion in Vdub, but that doesn't seem to do the trick.
All I want to do is convert these clips into a usable file with AS LITTLE quality loss as possible. I assume raw AVI would yield best results. I'm not 100% set on raw, but I don't want it to be too overly compressed either.
Anybody care to lend a hand here?
Many, many thanks in advance.
Anon1Guest
How do I convert 60fps to 30fps to halve file size?
By DigitalOxygen.ca in forum MacReplies: 33Last Post: 11th Jul 2012, 21:27 -
Encoding 30fps from 60fps source, keep maximum smoothness?
By squall0833 in forum Video ConversionReplies: 22Last Post: 12th Apr 2012, 23:57 -
Shoot 60fps or 30fps for YouTube?
By vid83 in forum Video Streaming DownloadingReplies: 5Last Post: 18th Jun 2011, 12:42 -
Frame rate fore converting MTS video to avi
By nicholasrumin in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 13:57 -
Converting 720p/60fps file to 30fps?
By mt123 in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 12:34
