right so i just want some advice really
i have a dvd recorder with a firewire port and there is one on my laptop as well
i have been thinking about connecting the Laptop to the TV for a while and forgot about the port on the DVD player i was going to use a VGA (if that works)
will i be able to use the firewire and browse the internet??
i would just try it but i am moving house so TV is off the wall and electrics packed.
it would be nice to just set the TV up once as i hate chasing wires and stuff so im doing it once lol
also i have a usb on my satellite decoder could i use this instead id rather not as the USB port is at the front and would look unsightly
any help would be appreciated although i know very little so please remember in your replies you are talking to a moron![]()
The firewire port in most DVD recorders works only when a camera is connected, and cannot be used to transfer any other data. In a small number of cases you can use it to transfer footage off the DVD recorder to a PC. Your manual will tell you which is which. In the case of the former (and most common), they will not recognise a computer when it is plugged in, as it doesn't behave exactly like a camera. You might be able to use DV software (like Enosoft or WinDV) to make your PC respond like a camera, but only when transferring DV footage to the recorder.
In short, you cannot use this to connect your PC to your TV.
If your PC has a VGA port (many LCD/Plasma TVs do) then this would be your best option.Read my blog here.
cheers mate
that is what i thought to be honest but it was worth a try though
How to get Firewire on my laptop
By kelemvor in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Aug 2011, 22:14 -
My Laptop not recognising my camcorder via firewire ?
By topcat0001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Aug 2010, 10:27 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Video from Laptop to TV Using Firewire
By melc in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2008, 21:20 -
can i record laptop video to standalone dvd recorder via firewire?
By beatz2005 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 17th May 2007, 08:54
