I've burned a VCD using Easy CD Creator 5 Platinum and It plays in my DVD player and everything but the video looks a bit disgusting. I know VCDs don't look that great but what's with the pixels and blocks in some fast moving scenes and such? I've burned a VCD before with VCDEasy using CDRDAO and the video has no pixels or blocks whatsoever. The audio was just bad. What could the problem be and how might I be able to fix it?
As for the recording speed I'm using, the lowest I can go is 8X I don't know if that has anything to do with it.
Ummm, it would help to know what the source material for the VCD was from and which DVD player was used.
Blocky MKVs
By romanticwarrior in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Dec 2010, 15:06 -
FFMPEG too blocky
By IMC in forum Video ConversionReplies: 4Last Post: 3rd May 2009, 16:00 -
Blocky or Boxy?
By jethroangel in forum EditingReplies: 2Last Post: 10th Oct 2007, 21:18 -
QT DV blocky playback
By Fifou in forum Video ConversionReplies: 5Last Post: 7th Aug 2007, 10:56
