Results 1 to 12 of 12
    Jan 2010
    I'm working on a project of importing all of my 8mm/Hi8/D8 and HDV content into my computer. Is there a very simple and free program that will handle the basic DV transport method and input into a digital file, with the option as separate files for each clip, or 1 long file? I do not need any other capability but to control the camera to start/stop playback and import the file. The program would need to work with Win 7 x64.
  2. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
    Jan 2004
    Iowa, USA
    Try searching "Tools" (left side of screen) -- there may be others you like. But, WinDV gets my vote.
  4. windv
    not sure if it works with 7
  5. Member fitch.j's Avatar
    May 2009
    windv
    it does work with W7
    Jan 2010
    Using WinDV, working just fine on Win7 x64.
  7. I used Stoik Video Capture with excellent results in the past. I highly recommend it. Very small and a tiny footprint.
    Oct 2006
    Hi,
    There's an excellent free software for capturing and processing DV files on the fly. It's called Enosoft. You can find it at: www.enosoft.com
    It's a teriffic program.
    Cheers,
    Fred
  9. Member 2Bdecided's Avatar
    Nov 2007
    Originally Posted by mediachimp View Post
    Hi,
    Cheers,
    Fred
    It has many useful features, but the scene-splitting in the enosoft software isn't frame-accurate. IME it loses about 0.5 - 1 second of video at each scene change. WinDV rarely loses anything - sometimes I suspect it loses a single frame, but that could be the camcorder.
    Cheers,
    David.
  10. Originally Posted by 2Bdecided View Post
    Hi,
    Cheers,
    Fred
    Cheers,
    David.
    That's about right. For frame-accurate splitting, I recommend WinDV.
    [FWIW, the reason I didn't make it frame-accurate (which would require more processing and more of my time) is because most scenes have a second or two of stuff you don't need and, once dropped on to an NLE timeline, will be trimmed off. The logger, though, is frame-accurate and creates EDLs.]
    John Miller
  11. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    OP mentioned HDV. For that use HDVsplit.
    http://www.kiva.org/about
  12. Anonymous
    Guest
    Removed.
