Hi guys, I've hit a snag here. I usually use mkv2vob to convert my MKVs to MP4s with subs. Apparently I ran into a problem where the file has VFR. So i did the conversion and of course the Video is out of sync with the Audio. I searched around on the forums and someone mentioned using Handbrake which is another program I frequently use to convert AVIs to MP4s. I did the conversion with Handbrake and the Video synced well. Problem now is subs. I researched more that Handbrake doesn't support hardsubs. Or does it? I watch my vids off of my PS3 so I always convert vids with hardsubs. Bu this VFR issue is a problem. Any well recommended program that can work with VFR MKVs and do hardsubs? I tried Xvid4PSP but that doesn't work with embedded subs into the MKV. I'm just trying to avoid the hassle here of extracting the subs and all that too.
But if the solution lies in me having to extract the Video, Audio, and Subs from an MKV and use (forgot the name of the program here) to pack into an MP4. I will go that route. But has anyone done that to MKV's with variable framerates?
Thanks if someone replies!
Results 1 to 13 of 13
actually i found my solution even tho i didnt get a response and that is called Format Factory. its pretty much going to replace my Handbrake. on sync video and audio with hardsubs encoded. consider this thread closed then. but id appreciate for anyone who has a problem as mines is to recommend Format Factory.
I remember AlanHK saying that Format Factory instals a lot of unwanted codecs and stuff that he found difficult to remove. Is there any way to avoid that?
thank you for making me aware of that... i did notice the change in settings with my codecs... i use a combination of both CCCP and CoreAVC... what happened to me was that it defaulted both the settings in my FFDShow Filter cancelling out my CoreAVC... all i id then was uninstall CCCP and reinstalled it... during the installation of CCCP it asked me disable a few codecs that came with Format Factory i believe because it never asked before... so i disabled H264 in my FFDShow settings... set CoreAVC as my external filter in MPC... and bam... im back to where i was before...
as for the unwanted codecs that came with Format Factory... they dont seem to be in the way of my CCCP and CoreAVC at all... i believe they are mostly meant for the purpose of using Format Factory and thats it... so if you do get rid of codecs that came with Format Factory you probably may make that program unusable... that is just my theory on the matter as those codecs im not even going to touch or bother...
if it bothers you that much... i say reformat the entire computer so you get a clean slate... install Format Factory first... then the CCCP Package... (along with CoreAVC if you need to)... -
Hmm, what you say just makes me even more reluctant to instal Format Factory.
It's probably fine for someone who doesn't use any other video applications, but anything that messes with existing settings (without a choice or even a warning) is a no-no for me.
Just my 2c. -
Basically, it's a codec pack with a converter that uses these.
The installer did not give you any choice of using existing codecs; it installed a whole bunch in its own folders and these replaced any existing codecs, even if they were the same ones in a different location.
It'd be fine if it just installed the converter front end and let you choose if and where to install any codecs. But it just pushes everything else aside. -
well either way... the codecs from the program arent interfering with anything else in my part... so its fine with me...
i already did and all my video programs are fine... i even listed what i did to resolve my issue... but this case is different for different people... so all in all... it works for me... it may screw some others up... my situation for this thread is resolved... so then... thread closed... because any more reviews bout format factory has nothing to do with my problem of tryin to watch vids with variable framerates on my ps3 in mp4 formats...
peace and thanks...!! -
Thanks for the program. do you know why subtitles aren't showing up with correct font when I use formatfactory though?
Every video I make with Handbrake mkv has framerate of 90000 & wont convert
By Onceler2 in forum Video ConversionReplies: 7Last Post: 12th Sep 2011, 11:26 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05 -
Canon EOS movie: variable framerate problem
By jullebarge in forum Newbie / General discussionsReplies: 7Last Post: 19th Jul 2009, 18:54 -
Variable FRAMErate dvd demuxing
By gbi in forum Video ConversionReplies: 8Last Post: 11th May 2009, 08:24
