Am facing a strange problem while playing the file mentioned below with MPC/CCCP. The Video playback is lagging behind sound. Playing with VLC is hopeless. What might be the reason behind this nuisance![]()
File Information:
Filename: 2010.Long.Beach.Race.TSN2HD.x264.mp4
Filesize: 1.37 GiB
Format: MPEG-4
PlayTime: 01:39:12.853
1 video stream(s), 1 audio stream(s), 0 subtitle stream(s).
Video Stream 0:
Length: 01:39:12.830
Frames: 356813, 59.940 fps, 1806 Kbps
Codec: avc1 (Family: )
Dimensions: 704x400, AR: 16/9
Audio Stream 0:
Codec: AAC, AAC,
Bitrate: 165 Kbps
Bitrate Mode: VBR
Sampling Rate: 48 KHz
Channel(s): 2 channel
Resolution: 16 bits per sample
System Information:
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3
Processor: Intel(R) Pentium(R) III CPU 1200MHz
DirectX Version: DirectX 9.0c (4.09.0000.0904)
Physical RAM: 510MB
Virtual Memory: 2047MB
Video Information
Video Card: Intel Corporation Intel(R) 82810E Graphics Controller (Microsoft Corporation)
Video Memory: 32.0 MB
Chip Type: Intel(R) 82810
Driver Filename: i81xdnt5.dll
Driver Version: 6.13.0001.3198 | 4/14/2008 05:41:56
Disp Settings: Samsung SyncMaster 550v | 1024 x 768 (24 bit) (60Hz)
Audio Information
Audio Device: Realtek AC97 Audio
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.6300 | 9/24/2008 10:40:22
Default Sound Playback: true
Default Voice Playback: true
Please respond. Thank you.
Yeah, I play all types of files. This Tualatin processor still works like a charm.
@Baldrick
a) VLC - can play but the video frames are getting struck. Audio out of sync.
b) MPC - Plays with excellent video quality ( 704x400, AR: 16/9) but Audio out of sync
c) Tried SMPlayer just now: Plays the video with excellent quality AND Audio is on sync too but the Video is getting struck for every 2-3 secs of playback
I am unable to get what might be the problem here. I don't think this almost 9 year old PC (Moms) Hardware is the reason because I can do all sorts of things. Example:
Re-encode the same file above to Xvid (1800 Kbps quality). Tool used: iWiSoft Free Video Converter (superb one)
I did re-encode some 10 min of playback time (it took some 50 min. LOL) to cross-check whether that AVC has any issues or not. Xvid output file works like a charm. But, why doesn't this AVC file play
Note: Same file plays very nicely on my i7-860 Workstation.Last edited by bulava; 19th Jun 2010 at 13:40. Reason: Note
When I can play this file then why not those files
Filename: MotoGP.2010.Round04.Mugello.Qualif.EurosportUK.x26 4.English.mkv
Filesize: 844 MiB
Format: Matroska
PlayTime: 01:26:20.520
Application: mkvmerge v3.3.0 ('Language') built on Mar 27 2010 09:34:43
Application: libebml v0.7.8 + libmatroska v0.8.1
Video Stream 0:
Length: 01:26:20.520
Frames: 129513, 25.000 fps,
Codec: V_MPEG4/ISO/AVC (Family: )
Dimensions: 640x368, AR: 16/9
Audio Stream 0:
Codec: MPEG1/2 L2, A_MPEG/L2, MPEG1 or 2 Audio layer 2
Is it something to do with HIGH frame rate of those files
Even I suspect the high frame rate...but I tested the same file with Xvid re-encoding with 704x400 & 16:9 AR. It played lovely with MPC as well as with VLC. So frame rate might be issue or is it something else...
UPDATE:
Tried BS Player FREE and GOM Player. BS Player is the only thing which is doing good, if not the best. GOM was close but not on par with BS Player. But my point is when they can play why not MPC with CCCP
IE8 - unable to view drop down lists. Help!!
By thegeeman in forum ComputerReplies: 4Last Post: 18th Aug 2010, 11:01 -
Sync audio starts-ok but near end 1 sec lag H.264/MPEG-4 AVC AAC LC
By JoeBolden in forum Video ConversionReplies: 6Last Post: 7th Jan 2010, 15:31 -
unable to view live webcasts?
By Mr anderson in forum Video Streaming DownloadingReplies: 2Last Post: 24th Feb 2009, 12:31 -
unable to view files on dvd
By axe1992 in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2008, 09:00 -
VirtualDub unable to keep audio sync'd on *source* audio
By falconne in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:12
