I get a green screen when loading an avi into TMPGEnc.
The same video gives a black screen when loaded into VirtualDub-1.8.6
The video plays OK in Media player.
My end goal is to use the video in TMPGEnc.
Attached below is the specs on the video file according to MediaInfo.
Thanks!
Bob
General
Complete name : E:\My Documents\Docs of Bob\Part1of2.avi
Format : AVI
File size : 169 MiB
Duration : 6mn 40s
Overall bit rate : 3 547 Kbps
Writing library : VirtualDub build 30009/release
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : H264
Duration : 6mn 40s
Bit rate : 2 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.072
Stream size : 95.4 MiB (56%)
Writing library : x264 core 1679553132Dec 17 2008
Encoding settings : cabac=1 / ref=1 / deblock=0:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / psy_rd=0.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=30 / mbaff=0 / bframes=0 / keyint=250 / keyint_min=1 / scenecut=40 / rc=abr / bitrate=2000 / ratetol=1.0 / qcomp=0.50 / qpmin=2 / qpmax=31 / qpstep=4 / ip_ratio=1.40 / aq=0
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 6mn 40s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 73.3 MiB (43%)
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 500 ms
install ffshow and enable h.264/avc in the vfw configuration (yellow icon)
OK, I downloaded ffdshow Tryouts since they said that was the more current version... And it worked!
Question, I did not try to set the enable h.264/avc in vfw configuration... will that cause a quality problem by not having set it?? I tried to see how to get to the ffdshow Tryout conf screen again but even when I reinstall it does not show up again. Hmmm.
Thank you that you got it working!
Bob
How to use green screen with video?
By MitchStevens in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jun 2009, 19:33 -
Underwater Green Screen
By kccannon in forum EditingReplies: 6Last Post: 21st May 2009, 19:35 -
Funny green screen
By timmythesaint in forum Newbie / General discussionsReplies: 18Last Post: 14th Apr 2009, 14:41 -
Screen turns green
By boysha in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 13:46 -
green screen in convertxtodvd
By fruitpassion in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jun 2007, 00:16
