  1. Hi,
    does anybody know the region free codes for a Samsung DVD C550k?
  2. Try this, it worked for my area 4:
    Region code hack posted by rihedor, June 24 2010:
    The above mentioned hacks did not work for me
    but I've tried the one posted for DVD-P191 by bjorninn
    and it worked for my region 2 - player.
    only it didn't show the number '9' in the left corner of the screen, but '0'
    As stands for region "0" = region free.
    It works fine on my region 1, 2 and 4 dvd's
    this is wat was posted by Bjorninn
    1. Turn player on with without disc in tray.
    2. Wait until "no disc" appears on TV screen
    3. Press "repeat" (not "repeat A-B"!) on remote.
    4. Press in sequence following keys:
    Region 2 players: FF, FR, FF, UP, DOWN
    Region 3 players: FF, PLAY, FR, UP, LEFT
    Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    Region 5 players: FF, UP, DOWN, STOP, RIGHT
    Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
    Number "9" must appear in upper left corner of TV screen,
    that means that sequence was successful and player is now
    region free.
    If it does not appear turn repeat from beginning.
    After successful sequence turn player off and on again just
    in case.
    Just be sure you know what region your player is before you
    begin
