Sometimes the extraction will be "finished" in 2-5 seconds, but no MPG is output, and there are no other error messages. In the Output Log is nothing more than the timestamp of when the extraction "finished". At first it only happened with VOBs that I authored using inexpensive software, but now I found a production DVD that duplicates the exact problem. I've attached the IFO files of the production DVD.
Which mode? IFO or VOB?
This one must be a stumper!
Is there any other info or files that I can provide to help figure this out? -
It is (and i have been away....). I will need you to upload some of the DVD (propbably the first VOB). If i give you my FTP details - would you be able to upload it?
It turns out this was caused by a comma in the folder name in the path containing the IFO files.
Thanks ChrissyBoy for the support!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2011, 23:34 -
VOB2MPG PRO V3.0 on XP, worked fine at first, now can't start extraction
By VideoThug in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 12th Jun 2010, 14:21 -
Question re "lossless" extraction of clips for later DVD authoring
By TURB0x in forum Authoring (DVD)Replies: 4Last Post: 9th Jun 2010, 05:08 -
Who made Maxell MIJs? And Difference between "Pro" and "Valu
By mrlar2 in forum MediaReplies: 4Last Post: 10th May 2007, 16:55
