Hi, I use the program called AVStoDVD. i inserted a .mp4 file and wish to burn it. after it started. A program called HCenc 0.24 appeared and i think it is encoding the video. It is done with pass 1 which took me several hours and then at pass 2, i've got a problem. It stops at 93% and the info says that "WARNING, small source mismatch found in pass 2, count: 89 frames. The fps box is not changing, the current is: 0 and the time left is fixed with 13 mins. Please how can i fix this problem. i am new to this things and knows a little bit only. Please if someone knows the solutions. I appreciate any help. Thanks![]()
Thread moved to video conversion forum.
See this thread for some ideas:
https://forum.videohelp.com/threads/318961-%28HCenc%29-WARNING-small-source-mismatch-fo...ss-2?p=1975263
Problem with HCenc 0.24.
By HolyFries in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2010, 14:18 -
HCenc Question
By Maikeru-sama in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 13:01 -
HCEnc vs MVBR
By awesomer in forum Video ConversionReplies: 7Last Post: 31st Jul 2008, 19:12 -
HCenc encoding problem (2nd pass)?
By ecc in forum Video ConversionReplies: 49Last Post: 29th Nov 2007, 02:22 -
HCEnc
By Belfour in forum DVD RippingReplies: 1Last Post: 28th Jun 2007, 10:57
