Hi guys
I've used DVD Flick for a while now(win XP),but only recently on windows 7 although without problems at first,i'm getting a problem(for the last week) where it says burning is complete yet out of the 2 movies the 1st one will only past for 30 minutes or so then stop or loop back to the start again,same when i try to put say 6 or 7 short 30 minute series onto one dvd it will take the normal two or so hours to convert and burn yet will only play a few minutes of the 1st one when i try the disc..
When i just burn one movie at a time its also the same just 1/2 the film,i always watch/check the movie 1st to make sure it plays fully on the pc before converting/burning..
I'm using the newest version and have tried 3 or 4 older versions,still no joy .
99 % of the files are avi i'm putting into DVD Flick and have never had problems before..
Anyone shed any light on the problem ?
blessed be
Results 1 to 1 of 1
Create Layer Break Position in DVD Flick / Img Burn
By Akhet in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2011, 10:44 -
DVD FLICK Bug? 1.0.3.6 version won't encode mpeg2 files properly...??
By bahjan in forum Authoring (DVD)Replies: 0Last Post: 21st Jan 2010, 06:40 -
Ulead DVD Movie Factory won't burn DVDs after had been working fine
By alh132 in forum Authoring (DVD)Replies: 4Last Post: 12th Mar 2009, 15:47 -
Do I use NTSC or NTSC-movie in DVD Flick?
By Belfour in forum Authoring (DVD)Replies: 1Last Post: 15th Sep 2008, 10:11 -
New guy, movies won't play on certain DVD players?
By koreninja in forum DVD RippingReplies: 6Last Post: 12th Oct 2007, 22:53
