This is an Avisynth script that I have had for a while.
It takes the text and brings it in at the lower right of the frame, it moves to the left in an ascending trajectory and at frame 200 it ends.
I've seen similar examples but none explain in simple language what each of the parameters does.
anyone know what the red values mean.
AviSource("cd1.avi")
Animate(0,200,"subtitle", "Goodbyeeee!",720,576,0,0,"Arial",40,$FF0000,$00FF00, "Goodbyeeee!",0,200,200,200,"Arial",40,$FF0000,$00FF00)
I read it and don't understand it.
The example in the link: are 25/130 and 160/120 referring to frame numbers or pixel positions and what is o and 99999 ?
Animate(0,48,"Subtitle", "Hello, World!",160,120,0,99999,"Arial",0,
\ "Hello, World!",25,130,0,99999,"Arial",48) -
(160,120) is the starting (x,y) position of the text and (25,130) is the final position.
In your original example, these were (720,576) [ie lower right] and (200,200).
0 and 99999 are the start and end frames for the Subtitle command, which means that once the animation ends at frame 48, the subtitle remains on screen at its final position until frame 99999 (or the end of the clip if sooner). Conversely in your first example, the subtitle will disappear at the same time as the animation ends, at frame 200.
For a full description of Subtitle parameters, see
http://avisynth.org/mediawiki/Subtitle -
Thank you, your explanation helped me understand and get the result I was looking for.
Editing After Effects Subtitle Script
By evil nemesis in forum EditingReplies: 0Last Post: 20th Feb 2012, 11:03 -
AviSynth - 'Animate'
By Hungarian in forum EditingReplies: 4Last Post: 6th Aug 2011, 12:04 -
Animate Videos (2D)
By Xaser in forum Newbie / General discussionsReplies: 3Last Post: 12th May 2011, 08:22 -
AVS script and Subtitle Workshop
By sambat in forum SubtitleReplies: 3Last Post: 19th Apr 2009, 10:20 -
Maybe Off Topic but how do you write a script/subtitle?
By Han Solo1 in forum SubtitleReplies: 1Last Post: 4th Mar 2009, 10:18
