main objective:
how to specify, incorporate, make possible, for a specific subtitle font (or group) to be played on a external DVD player with these parameters:
the video is a avi format file (any specific edtion?)
the subtitles are on separate files, not incorporated (any specific extension for the mentioned purpose?)
alltogether is recognizable by the DVD external player (for television, not PC)
hypothesis?:
to put on the same subtitle and video file folder, the font file of the chosen subtitle font?
are these parameters specified on the editing software during the edition process of the avi file?
Thank you for your support
Cheers
Jose Pedro Gomes
Results 1 to 18 of 18
Last edited by Ze Tomes; 17th Jun 2010 at 20:38. Reason: make crystal the thread posted
anybody out there?
a twin soul with the same problematic questions... no...? -
is my thread that complicated or impossible?
ok... 3-me replies will do the job I think -
Hi there.
Ordinary standalone DivX/XviD players do NOT support "custom external fonts".
Some of them support only .srt files, other accept idx+sub as well,
and I've not seen yet a model that understands .SSA or .ASS files
(which can contain embedded fonts). If you want to see "as many fonts as possible"
on your subtitles, the only choice is: .ssa --> .son --> .idx+.sub
(assuming your SAP accepts bitmap subtitles).
HTH.Last edited by El Heggunte; 24th Jun 2010 at 00:57. Reason: making message crystal-clear
Hi HTM and thank you for your response,
im kinda new with editing video language, as I understood by your words there are only a few subtitle file extensions recognizable by the external DVD player (advisebly placed on the same directory of the main movie avi file): the font subtitle style (font, size and criteria) is inevitabely the one displayed by the external dvd player configuration (which can or not be selected by the dvd menu)? Did I follow correctly?
Cheers
The most common subtitle formats used by most players are plain text formats that contain no font information of text formatting beyond simple effects like italics. The font is provided by the player - usually a clean san-serif like Arial. So you have no control over size, colour etc. If you are authoring a DVD you have a little greater freedom because the subtitles are in fact images, but even then you are still limited in the number of effects etc. supported by most authoring tools. The greatest amount of freedom comes form software players running on PCs that can handle SSA or ASS format subtitles.
Read my blog here.
Appreciate very much your information Guns,
I was afraid of that, I thought it would be possible to incorporate on the same movie and subtitle directories the fonts you chose, i use to incorporate the specific subitle fonts on oriental movies as there's no turn over it - either you know japanese or you just have to stuck on subtitles, but as for as the other ones i think i'll continue the same process aon an english subtitle basis.
By the way some of my favorite researches (free fonts):
Swiss 721 Narrow SWA
Helvetica LT 57 Condensed
InterstatePlus Regular Cond
with this very simple but pratical software: any Video Converter
Cheers
Just accidently bumped into this thread, but you don't state what dvd player you have. Philips 5990 does support ssa files. You might want to read around the dvd player forum to see if your player does.
You also might want to look into software that will embed your srt files into the avi, and save it as a divx file. I use an old program called srt2bmp which does give me some leeway as far as the colour and size of the font, but I'm sure other people can make better newer suggestions.The torture never stops! -
Thanks Lizz for your tips,
Right now I don't have a DVD player, but it's already good to know that there are some DVD players that support SSA files, therefore font size, criteria and style configuration.
I do embed the subtitles on the extension avi fles, by xvid codecs with any video converter, the reason of this thread it was because I was trying to avoid that process on audio languages that I was familiarized with, just because in the future i would might change my ideas of subtitles aestethics and visual interpretation: while making separate the subs file and the movie i could always conjugate a group of most probable good subtitle fonts which I could always alternate.
Cheers
Thanks for the info about the Philips 5990 (it's difficult to remain always well-informed in the world of today...) Still, the SSA specs are not, let's say, "small", and not all players/filters support ALL features possible in a SSA file. Do you know if the 5990 does support SSAs with "embedded fonts" and/or in Unicode, for example, ?
Me neither. In the SSA specs, "embedded fonts" mean you don't need to have them installed (registered) on the operating system of your computer. IF the newest hardware players are able to load external fonts into their memory chips, that's a really-really GREAT feature indeed.
And that was exactly what I was trying to know
A new question comes to me: is there any free software that allows you to extract separetely both movie and subtitle files from a matroksa file?
(just found the guide for)
Cheers
To whom this may interest
https://forum.videohelp.com/threads/323309-DivX-Plus-supports-MKVs-with-embedded-fonts?...31#post2002131Last edited by El Heggunte; 15th Jul 2010 at 08:09.
Separate AVCHD video files for burning on DVD
By csh in forum Authoring (Blu-ray)Replies: 5Last Post: 13th Jan 2012, 02:01 -
Copying separate files from dvd's
By Peter1954 in forum Video Streaming DownloadingReplies: 1Last Post: 15th Dec 2011, 08:15 -
MKV with subtitles and fonts attached to ipod touch format?
By EwanG in forum Video ConversionReplies: 4Last Post: 19th Mar 2009, 17:27 -
Subtitles fonts are too big...
By nomis in forum SubtitleReplies: 4Last Post: 13th Mar 2009, 05:33 -
Can't switch between separate dvd-files
By SirTarhan in forum Newbie / General discussionsReplies: 8Last Post: 27th Mar 2008, 04:16
