I recently just bought a dazzle which came with Pinnacle Pro 8. Here's the problem: For 2 weeks, the dazzle worked fine. Then yesterday, I plug it in and it says "Device requires USB 2.0"
Why it did this? IDK!
Help would be much appreciated.
P.S. - I also can't get my microphone port on the front of my laptop to work and I really need it to do cartoon voiceovers coz that's my thing, if anyone could help out on that, it would be appreciated as well. Thank You!
I'm guessing your laptop does have USB 2.0? If so, not sure why the program would not see it. Check your USB ports in Device Manager. 'Control Panel>System>Device Manager'. If you scroll down to your USB listings and open them, you should see the word 'Enhanced'. That's a USB 2.0 port. You can try uninstalling the controller and rebooting to reinstall and that should reset it if that's the problem. The only other thing I can suggest is to uninstall, then reinstall the Dazzle programs.
With the microphone port, have you used it before with that mic? If it worked before, probably something in your audio settings. Those are also in 'Control Panel>Sound>Microphone'. If you haven't used that mic, make sure it's compatible with your mic inputs.
And welcome to our forums.
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
Dazzle DVC 100 PROBLEM A valid input Signal has not been detected, HELP!
By Leon Smith in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2011, 14:14 -
hd tv using dazzle
By zookeeper525 in forum Capturing and VCRReplies: 12Last Post: 11th Apr 2009, 22:14 -
Dazzle dvd recorder capture card and a VCR problem
By leeh in forum Capturing and VCRReplies: 5Last Post: 3rd Jul 2008, 13:53 -
Dazzle DVC 170 PAL Problem - 'mirrored' screen
By Glaucous in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2007, 06:58
