I was told by a Comcast employee (a friend) that if I bought an Ez USB Transfer Cable that I could connect it to the front USB port on the 8240HDC and transfer the recorded tv shows/movies to my PC. But to do this I would need the key codes on the remote to unlock the front USB port, well I haven't spoke to him in awhile and can't reach him but he was going to send me a file that he got from Comcast on how to unlock it and never got around to it, now I have lost touch.
My question is, does anyone out there know the key codes to unlock the USB port and if so does it really work to transfer shows/movies to my pc which I can convert to dvd?
Thanks in advance for your help.
It sounded a little off to me too, I always thought the only way was to connect Composite cables (red, white and yellow) from the out into a video capture card in your PC and then use the send to vcr feature, which you lose the HD quality if you have recorded a show from an HD channel but this is the only way I knew of. I'm looking forward to hearing if this is real or not myself LOL.
You can also record HD from the component outputs from the 8240HDC with a device like the Hauppauge HD PVR (I do this). And you might be able to capture recorded material via the Firewire output. I can do this too but there are a lot of errors in the stream (picture breaks up every now and then in HD, SD works fine). I don't know if the problem is in the output from the 8240 or in the capture at the computer. Live output from the 8240 appears to be encrypted at the Firewire port. Data is coming out but nothing can decode and display it, both HD and SD.
This behavior may vary depending on the firmware. I have Cox, not Comcast.
scientific atlanta cable box explorer 2000
By Darkcast in forum DVB / IPTVReplies: 1Last Post: 13th Mar 2011, 13:49 -
Disabling On-Screen Channel-Change Display (Scientific Atlanta Exp 3200)
By jillsy in forum DVB / IPTVReplies: 3Last Post: 15th Dec 2010, 00:12 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
Scientific Atlanta HD Cable Box / HDMI Audio Problem
By culttvguy in forum DVB / IPTVReplies: 5Last Post: 14th Sep 2008, 15:48 -
Scientific Atlanta 8300 HD/PVR Rogers Cable Recoding Required To Work.
By musicmavern in forum DVD & Blu-ray RecordersReplies: 6Last Post: 8th Aug 2008, 11:52
