My tv (hd 720 sanyo) suffered a lightning strike and now the hdmi input and the 5 composite jack inputs dont work. Is there a simple and cost effective way to downstep from hdmi, vga or dvi to either 3 piece rca, s video or coax?
Radeon 4650 hdmi, dvi and vga outputs
Not sure what you mean by '3 piece RCA',.... component? And it depends on what your source outputs are.
Some ATI cards can output component through a ATI adapter. Are you sure those other TV inputs are working?
S-video, maybe, depends on the card. Usually they come with a S-video adapter or socket if the output is available.
Coaxial (RF) would take a RF modulator, usually from the composite output. You could probably pick one up a Radio Shack or similar.
If your video card only has DVI and VGA, not so easy. Check with the card manufacturer. ATI licenses their chipsets to a lot of board manufacturers and they all have their own layouts.
And welcome to our forums.
reallyreallyconfused, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudzLast edited by redwudz; 16th Jun 2010 at 15:09.
Do you have a DVD player? If so connect 480i or 480p over analog component (Green-Blue-Red RCA) and see if the TV works.
Set DVD player menus for "NTSC" and analog component.
If it works, then we can figure out how to get analog component HD out of the ATI card to the TV.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
Need help from video experts, hdmi to vga to dvi
By edgarmiranda in forum Newbie / General discussionsReplies: 3Last Post: 20th Jun 2011, 23:24 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
Connect VGA/DVI/HDMI source to Component HDTV
By jstewar9 in forum Media Center PC / MediaCentersReplies: 0Last Post: 13th Jan 2010, 16:11 -
vga, dvi-hdmi, or svideo best cable for pc to 720p hdtv?
By yoda313 in forum ComputerReplies: 5Last Post: 12th Nov 2007, 21:37
