Im trying to download this video: http://www.mtv.com/videos/katy-perry/527631/california-gurls.jhtml#id=1518071
I tried using Url Snopper & rtmpdump but cant figure out how to do it.
Can someone please help me out. Thanks alot
Here's how I finally managed to record streaming videos after trying various Realplayer type HTTP grabbers. 90% of the time they don't record due to the commercial clip at the beginning or they are copyright encoded. I went the screen recorder route and looked for software that would record in virtually the same quality as the video stream. I found Camtasia 7. It's perfect for your purpose.
You can set your recording parameters for audio and video in any format, especially if you download ffdshow codecs first. After I played with it for awhile I found I could record Hulu videos and save them as though I had downloaded them directly. Let's use your video for example: we play it in the small[not full screen]window. Then draw our recording box with Camtasia within the video screen size. The recording parameters are set for output to xvid at 30fps and whatever bitrate you want. I use 1200kbs generally. restart the video and hit the record button. After stopping I save and open in virtualdub and lift the commercials and cut off the end if needed.
Try the free trial. http://www.techsmith.com/camtasia.asp -
Hi , use this:
http://www.empty-v-loader.ch.vu
If it works tell all your friends.
Thanx,
Daniel Schmidt -
Does anyone now how to get videos off mtv.com now. I was succesful with streamtransport but now it doesnt work no more
thanks alot
I want my mtv!!!
By drtalk in forum Media Center PC / MediaCentersReplies: 16Last Post: 10th May 2012, 15:43 -
need help downloading video from mtv.com and vh1.com
By Blah360 in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2010, 02:06 -
Convert to .mtv?
By calande in forum DVD RippingReplies: 2Last Post: 2nd Jan 2009, 10:57 -
MTV video
By Mark V in forum MacReplies: 16Last Post: 17th Nov 2007, 22:18
