Alright, I fully realize now I do not have enough computing power , time, money, or patience to go HD.
Screw it. I can do this with SD.
My question, I guess, is, do I go with a Canon FS20, or find a better slightly aged model used?
I'm going to be filming bands in likely a lot of low light situations.
Hoping to nab just the camera for around $500.
cheers,
hmd
Results 1 to 12 of 12
In the $500 range the best solution believe it or not is a used Canon HV20 or HV30 HDV cam. These shoot wide DV format with excellent quality*. In DV mode, they are compatible with most all edit software out there but not all handle wide 16:9 properly.
In the $1000+ range look for a good used Sony VX-2000/2100. These are great for 4:3 but not so great for 16:9. Their main advantage is optic quality, 3x CCD 1/3" sensors and good low light performance.
* Or you can shoot 1440x1080i HDV, but export Wide DV over IEEE-1394. You retain the HD version for the future.Last edited by edDV; 15th Jun 2010 at 20:58.
http://www.kiva.org/about -
So I can throw that into my decent computer with very little hassle and use all my same SD cards and such?
Sorry, I don't know a whole lot about this aspect of things. i've been doing things very ghetto.
I'm using a Canon Powershot SD1000 to film bands right now, and just want a huge upgrade (anything would be) that I can still throw on a computer, jump into Final Cut / Premiere, edit, burn, throw on youtube, vimeo, etc...quickly...
thanks! -
oh, so that camera uses these tapes i've been hearing about? haha.
do the tapes, being less compressed than throwing video onto sd cards, make it look better?
sorry, i'll admit i really know nothing about formats, equipment, aspect ratios, or any of this stuff.
i've been studying, but have been using such an archaeic, guerilla way of doing things, a lot of this stuff goes over my head.
sorry. -
haha, hey, i'm learning as i go here. researching it for the last few hours.
seems like a good fit.
even though audio is somewhat a non issue because i'll be using sound recorders / soundboard audio, i'd still probly have to get an external mic for that bad boy.
and no, not rock band videos....here's an example of stuff i'm filming from the other month (this is on my crappy canon powershot) :
low light and low budget don't work together , or you can't put them in the same sentence
by the way.I own the hv-20 .you don't need a powerful PC to transfer video to your hard drive plus it's easier to edit and safer for storage than camcorders based on hard drives/memory
http://www.hv20.com/
http://vimeo.com/1685127
http://vimeo.com/12459143
if you know some one who owns the hv20/30/ or the 40 model ask him/her if you can test it
if u still wanna flash camera.check the VIXIA HF200 you can get a refurb one for $399Last edited by MJA; 16th Jun 2010 at 13:22.
The Canon HV series are a two in one (plus2) deal. They shoot HDV MPeg2 or function as the best sub $2000 wide format MinDV camcorder. MiniDV is the best format for SD editing and post encoding short of full uncompressed. MPeg2 or MPeg4 GOP based SD or HD formats are an editing headache and suffer more recode loss.
The plus is you can shoot HDV but convert realtime in camcorder hardware to DV export over Firewire. This gives you an HD master but edit SD DV today. No AVCHD camcorder can do that. Another plus is the HV can output a live Firewire stream (HDV or DV) for live broadcast. No AVCHD has that ability. Uncompressed HDMI or SDI require expensive equipment for broadcast.
Plus you are dealing with $3.00 60 min MiniDV tapes vs. $30/hr Level 6 flash media. A 10x media cost advantage.Last edited by edDV; 16th Jun 2010 at 18:52.
I'll absorb all of that, and keep researching.
Thanks a ton, guys.
Appreciated. -
Another plus is you have a semi-pro user forum dedicated to this series
http://www.hv20.com/Recommends: Kiva.org - Loans that change lives.
2012 talk about
By Johnnylee_hang in forum Off topicReplies: 46Last Post: 11th Mar 2010, 04:13 -
Any good utility to join m2ts (or MTS) from AVCHD camcorders?
By sebaz in forum EditingReplies: 4Last Post: 17th Jan 2010, 12:10 -
Elbot- an AI you can talk to...
By ahhaa in forum ComputerReplies: 1Last Post: 16th Oct 2008, 22:44 -
Can I get 2 wireless routers to talk to each other?
By stblob in forum ComputerReplies: 2Last Post: 25th Feb 2008, 13:39 -
How good are MP4 camcorders?
By OM2 in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2008, 01:29
