  1. Hi this is my first post on the forum so id like to start with saying hi and great forum im sorry if there is a introduce yourself thread but i couldnt spot one or i would have posted there first.
    im having a little issue with Bd re-builder not seeing the free space on my hdd or it could possible be windows but i havent had this problem with any other program.
    Bd - Re-builder starts encoding then the progress gets to 5% then it stops responding then i get a notification box that say insufficient space on drive h:
    and then i end up having to close Bd Re-builder from task Manager
    no matter which hdd i choose this happens - any suggestions welcome
    USA
    I've only used BDRB a couple of times, but that does sound odd. I assume the drives do have sufficient space. Most of those type of programs use a temp file and you might check to see where that is going. About all I can suggest is a uninstall and a reinstall of the program.
    If you don't get any decent answers here, try Doom9 as the author of the program is there: http://forum.doom9.org/forumdisplay.php?f=75 I believe Doom9 still has a waiting period before posting.
    And welcome to our forums.
  3. thank you for the Quick reply il try deleting it and re-downloading to see if it makes a difference
