i have an 720,480 avi file in lossless lags format and i want to crop the bottom and right by 10 pixels each and then resize back to 720,480 but i was wondering before i do that will i lose quality if encoded back to lossless?
i want to crop because the video has loads of vhs noise etc on the bottom and on the right has a black bar inside the video which i need to get rid off.
so any suggestions welcome thanks.
There will be no additional compression losses if you use lossless format like lagarith. The only losses you incur will be from the upscaling and cropping. So in a sense you can define it as a quality loss (because it's deviation from the original) , but on the other hand you might say it's a quality improvement.
You can't do that on interlaced material.
Mask it, don't crop it.Want my help? Ask here! (not via PM!)
If you're going to display the video at something other than 720x480, then it's certainly a quality loss. Cropping without resizing involves only 1 (quality-reducing) resize operation (namely during playback), while resizing to 720x480 involves 2. The difference might be close to negligible but it's still a loss.
How to crop the black lines out an MKV (and lose a bit of the sides)
By marklittlevai in forum EditingReplies: 32Last Post: 30th Sep 2011, 18:34 -
Can I crop and resize video?
By maldb in forum EditingReplies: 6Last Post: 13th Jun 2009, 20:06 -
Video Crop and resize
By quxote in forum EditingReplies: 4Last Post: 27th Feb 2009, 12:48 -
Every Time I Crop, I Lose Quality!
By terminalh in forum Video ConversionReplies: 8Last Post: 18th Jan 2009, 14:04 -
DVDs to DV to DVD will I lose quality in video?
By Endzone in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2008, 06:08
