    Jun 2009
    Hello I usually rip BR's with tsmuxer and anydvd for decryption. tsmuxer stops at 7.8% and will not go past that. I tried dvdfab7 but it just keeps trying to read the disc and doesnt get beyond that. I have tried ripping to HDD with anydvd and it fails. Has anyone else had problems with Precious??? Thanks. ps. if it makes a difference i just rip main movie best audio and english subtitles. then i put the folders into an iso and keep it in that format. thanks again!
  2. If AnyDVDHD does not ask for an update, I should think the disc is being decrypted okay. So...maybe the disc is dirty or damaged?
    Can't answer your question specifically, don't have that movie.
    Pull! Bang! Darn!
    Jun 2009
    thanks for quick response..disc is clean i really dont know whats going on )=
    for what its worth i get no error with tsmuxer it just doesnt go past 7.7%
    Jun 2009
    i have dvdfab passkey a go. seems like a good decryption program but im not so sure thats the problem...could it be possible that even tho the disc is clean its some how damaged?
  5. Originally Posted by carlos28355 View Post
    It's possible, Saving Private Ryan Blu-ray was recalled because of authoring errors.
    Jun 2009
    damn i see ill try taking it back for a new one i guess. thanks!
    Jun 2009
    thanks for all your help! took back precious got new one rips just fine! please close this thread!
