I am refromatting my comp due to some malware that is slowing it down. When I reinstall Windows, there are two partitions C and D drive. Most of the OS stuff is on C, so I select that to delete partition and recreate partition.
I did not delete partition on the D. Is that ok? Does it mean the stuff on my D drive will still be there?
Is it safer to delete both drives and start over or is it ok just to delete the C only?
"D" drive is ok to delete only if you don't have data on there that you need to keep. If you have data on it then there's no reason to delete the partition. Just delete "C" because that's where windows is.
Except that if the reason you are re-formatting is to remove a virus, you may very well be wasting your time leaving files on D:, as some of them may be infected.
The reason re-formatting works is that it gets rid of EVERYTHING. The described procedure does not do that.
Reformatting My Picture Library
By fmagreed2 in forum ComputerReplies: 7Last Post: 3rd Feb 2011, 14:15 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
avi to avi reformatting issues.
By lostinthematrix in forum Video ConversionReplies: 1Last Post: 18th Jan 2008, 12:19
