I am new to video conversion. I found out Virtualdub is a very good video editor. I used it for AVI files. I also installed MP4 & FLV import plugins. But when I try to import an MP4 file, I get an error.
"Unable to locate a video codec to decompress the video format 'avc1' (unknown)".
I have K-lite mega codec pack 6.0.4 installed on my Windows Xp SP3. And I can also play the file in Windows Media Player. Still can't import in VD. Maybe some settings are incorrect. Or any other problems???
Any suggestions???
My VD version is 1.9.9. Below is the file info I am trying to import in VD.
General
Complete name : G:\Movies\Vertical Limit\Vertical Limit.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.10 GiB
Duration : 2h 4mn
Overall bit rate : 2 417 Kbps
Encoded date : UTC 2009-07-11 03:35:55
Tagged date : UTC 2009-07-11 03:35:55
Writing application : Yamb 2.1.0.0 [http://yamb.unite-video.com]
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=24
Codec ID : avc1
Duration : 2h 4mn
Bit rate mode : Variable
Bit rate : 2 119 Kbps
Maximum bit rate : 12.9 Mbps
Width : 1 280 pixels
Height : 688 pixels
Display aspect ratio : 1.860
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.100
Stream size : 1.82 GiB (87%)
Writing library : x264 core 67 r1165M 6841c5e
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=abr / bitrate=2119 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Encoded date : UTC 2009-07-10 18:11:51
Tagged date : UTC 2009-07-11 03:40:31
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 2h 4mn
Bit rate : 320 Kbps
Maximum bit rate : 450 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 285 MiB (13%)
Encoded date : UTC 2009-07-11 03:39:59
Results 1 to 1 of 1
How to open .MP4 files in virtualdub? (i want to sharpen mp4
By fuc847 in forum Video ConversionReplies: 27Last Post: 22nd Apr 2015, 08:06 -
Importing h.264 mp4 files into After Effects bug?
By Flynn in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2012, 09:17 -
Importing .mp4 files into Avid MC 5
By barrylay in forum Video ConversionReplies: 9Last Post: 12th Mar 2011, 20:19 -
Problem with MP4 files and VirtualDub on W7
By asterixvader in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2010, 16:09 -
editing mp4/flv files from youtube in virtualDub
By tolland in forum EditingReplies: 2Last Post: 16th Nov 2009, 16:50
