When loading an avi to trim i sometimes get
"VirtualDub has detected an improper VBR audio Encoding in the source AVI and will rewrite the audio header with standard CBR values during processing for better compabability. This may introdece 37294 ms of skew from the video stream. If this is unacceptable, decompess the *entire* audio stream to an uncompress with a constant bitrate encoder. (bitrate:136.8 [(+-)(these are on top of one and other)] 24.0 kbps)"
All i want to do is trim the credits off of a movie that the file is too big to fit on a 700MB CD.
Is there a simple way around this or another program i can do this in. Tried AVIChop but that program just makes a mess.
Thanks for any help you can give me.
Use an earlier version of Virtualdub (1.3.x) and this message goes away...
I assume if the message doesn't appear that it leaves the sound alone.
Where can i get an earlier version?
p.s.
just tried virualdub 1.4.5
didn't get the message but the audio was way out of sync
Help! -
Try the VirtualDub MP3Freeze version.
If u can't find it, send me an e-mail "counting10@hotmail.com".
Need help with virtualdub error involving VBR encoding
By Hark in forum EditingReplies: 16Last Post: 11th Feb 2010, 23:45 -
Virtualdub has detected an improper VBR audio encoding
By lingoguysw5 in forum AudioReplies: 17Last Post: 26th Oct 2009, 10:12 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
virtualdub has detected an imrpoper vbr encoding...The current preference..
By von_25 in forum Newbie / General discussionsReplies: 11Last Post: 25th Mar 2008, 01:57 -
VirtualDub-MPEG Warning Improper Join?
By geewhiz in forum DVD RippingReplies: 2Last Post: 23rd Jun 2007, 07:10
