A while back, I picked up a ATI TV Wonder HD600 PCI card with the hopes of converting a bunch of old home made VHS tapes into .avi files and then DVDs. But, I was never able to find a good software for capturing with this card. I have basically no experience with this kind of thing. So, I really don't know what I'm doing. Could someone point me in the direction of a good program (or programs) that might do the job. Any help (including tutorials) that anyone can provide would be very appreciated. Thanks.
Results 1 to 13 of 13
Use Catalyst. I plan to make a tutorial for this next month.
What he means is use the software supplied with the card, download it from ATI if you didn't get it. The ATI capture utility is just fine and it can capture directly to MPEG2 (DVD format), but if you need to edit the capture you're best capture in AVI. You can then use your video with any editing or authoring software to make DVD's.
Get it here:
http://support.amd.com/us/gpudownload/windows/10-4/Pages/tvtuner_win7.aspx?type=2.5&pr...-Bit%20Edition
If your OS is not 7, look for the one you need in the column on the left.Last edited by nic2k4; 13th Jun 2010 at 15:10.
I am using Windows XP. Is this the proper software: http://support.amd.com/us/gpudownload/windows/10-4/Pages/tvtuner_mce-xp.aspx
OK, I installed the software but I'm having a hard time finding the program to open it. It looks like it was just drivers. I installed the control panel too...but I can't seem to make it work.
You're missing ATI Multimedia Center; use the direct link.
It looks like your card doesn't come with that; it wasn't offered for download with the driver. I don't know if it will recognize your card. You can always use other software to capture, VDubMod is a good choice. There are others too, look through the guides to learn more. -
Catalyst MMC is what you use for that card -- not ATI MMC. Confusing, I know.
The disc that came with the card.
OK, I got it all installed...but now I go into the program and I click "TV" and it says no tuner device found. The card is in there...and can't imagine I messed it up. Any ideas?
VirtualDub and GraphEdit work well with all Ati Theater chips.
Read this post from first link and the second thread:
https://forum.videohelp.com/threads/313735-Capture-card-for-Laserdisc-and-VHS-Good-card...=1#post1940752
https://forum.videohelp.com/threads/319062-Very-poor-performance-on-ATi-650-USB-PLZ-HEL...=1#post1975945
Capturing TV Broadcasting using ATI TV WONDER 650 PCI
By jluke in forum Capturing and VCRReplies: 3Last Post: 6th Nov 2009, 00:10 -
I have questions about this ati all-in-wonder pci-e card
By yoda313 in forum ComputerReplies: 0Last Post: 6th Sep 2008, 09:23 -
Good Firewire PCI card for Capturing HDTV?
By superdud1400 in forum Capturing and VCRReplies: 1Last Post: 12th Jun 2008, 05:11 -
I need a good FireWire PCI card for capturing video.
By mob in forum Capturing and VCRReplies: 11Last Post: 1st Apr 2008, 01:19 -
problem with the ati tv wonder pro pci card
By SabbathPwns in forum Capturing and VCRReplies: 0Last Post: 7th Jul 2007, 03:21
