I had made several large light weight wooden frames for fabric and oil paintings, up to 72" x 60".
With the right type of fabrics, I should able to make a home brew projection.
So, I don't have to project video on a blank wall.
What fabrics that I can get from JoAnn Fabric or Walmart to build a good projection screen ?
How much harder is that to figure out a back projection screen ( instead of the front projection ) ?
Some people use a flat wall and special paint such as ScreenGoo but most use material on a wall:
http://www.bigscreencenter.com/Projector-Screen-Material-s/848.htm
Any fabric would work for front projection but back projection requires special material.Last edited by MOVIEGEEK; 13th Jun 2010 at 13:55.
The trouble is projector only work well in my man cave in the basement.
I am planning to occasionally set it up in the bed room to watch some late shows.
I was looking for screen material wit high gain, to get a brighter picture in the bed room.
From your link, now I know high gain material has limited viewing angle. THANK YOU.
Rear Projection TV Help
By Alienverse in forum Newbie / General discussionsReplies: 3Last Post: 13th Jun 2008, 23:34 -
New build video editing computer--- screen goes black.
By rcguy1 in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2008, 07:04 -
Projection TV
By joytimeday in forum DVB / IPTVReplies: 3Last Post: 3rd Jan 2008, 23:57 -
For DLP projection TV, is LED a must ?
By SingSing in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2007, 20:48 -
anybody know how to refocus a projection tv?
By tonydahose in forum DVB / IPTVReplies: 2Last Post: 6th May 2007, 08:52
