  1. Hey guys i ve been rippin 1CD and 2CD rips quite well, but recently i ve seen some 350mb 720p rips, which have almost the same
    quality as of 700mb rips, Obviously the source is Bluray fr rippin thz kinda ones.And i ve been tryin them as well and the
    problem was i am not able to retain the quality of it as Experienced rippers are doin it. and i referred some and came to
    know tht by changing the different frame stuff i can retain the quality and i ve tried it and the rip was still nt gud,
    so can anyone help me in letting me knw wat r the things i need to take care to retain the quality of the rip.
    >>>Here is the way i do it using MEGUI<<<
    AVS script creator > add my file > i keep the scan type progressive if its not >save
    video section > avs is loaded > i config my codec (x264) > container as MKV > bitrate calculator(setting file size to 350mb) > enqueue
    audio section > audio file is loaded > config my codec (nero AAC) >enqueue
    and thn il START my jobs.
    plz help me guys i ve been tryin for a week b4 posting here,
    i am DYING TRYING nd TRYING (nice quote na ).
    Here is a view at my try
    SOURCE
    FINAL RIP
  2. You can't compare filesizes from different sources, because a longer movie/video will end up with a lower bitrate at the same filesize (filesize = bitrate x running time)
    Also the content complexity matters. An action movie, for example , with lots of explosions will require more bitrate than a slow moving drama for a certain level of "quality"
    Also, your aspect ratio is wrong
  3. ya the one i am tryin to rip is a drama so i dnt thnk any problem with tht and the run time is 2h 35min so thts a point of consideration and wat do u thnk the aspect ratio shld be!( i ve made it to 2.35 nw is tht ok)
    and should i use any filters in avisynth if so plz suggest me hw to and wat to use !
