Whenever I run the x264 I downloaded (http://www.free-codecs.com/download/x264_video_codec.htm) When I run it all it is a command line (I have windows). It does not show up in my Sony Vegas Pro 9. Could anyone tell me how to use it?
Results 1 to 10 of 10
It's a command line encoder, it doesn't integrate with vegas. There are many GUI's for it, eg. megui, ripbot264, handbrake, xvid4psp
You can install the vfw version, but it tends to be not very stable with vegas in my experience
http://sourceforge.net/projects/x264vfw/
or
http://komisar.gin.by/
Another option is to use debugmode frameserver to frameserve out of vegas into the x264 encoder or GUI for it.
Another option is to export a lossless intermediate, or uncompressed out of vegas into x264
If you want to learn command line options and what the settings do
http://mewiki.project357.com/wiki/X264_Settings -
^I highly suggest that you DON'T use ffdshow's vfw h.264 encoder, it's even worse than sony's or mainconcept in vegas implemenation . It hasn't been updated in years and gives horrendous quality.
So how do we replace ffdshow's h.264 encoder with a proper one so that it will be as easy accessible through Sony Vegas?
You don't mention a stable implementation that integrates with SV so I guess it does not exist. Well, it seems reasonable to try out the http://sourceforge.net/projects/x264vfw/ first. Thank you very much!
I though I mentioned this in your other thread, but your levels won't come out correctly if you use the vfw version through vegas pro for your screen captures (not sure about the studio version). Grey will become white. Even using a computer=> studio RGB filter doesn't correct it properly. Rendering out uncompressed then using x264 CLI works fine in my tests. The vfw version is also slower than the CLI version, even through vdub (I think it has to do with the VFW 1 frame in 1frame out model). It's also prone to crashes in vegas, at least for me
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 09:12 -
x264 doesn't encode h.264
By thuriel in forum MacReplies: 9Last Post: 20th Oct 2009, 15:09 -
X264 or H.264
By user123456 in forum Newbie / General discussionsReplies: 9Last Post: 25th May 2009, 17:21 -
HDTV(H.264) to x264
By kornhulio in forum DVB / IPTVReplies: 30Last Post: 4th Jan 2008, 17:37 -
HD-DVD compliant AVC/h.264 using x264
By miamicanes in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 11:39
