I have successfully created many DVDs based on footage from my 2 Canon HF10 cameras. The last attempts, though, have not been pretty. When the persons on the movie are moving the "edge" of a person is zigzag'ed, when movement stops the person appear as normal again. Not sure if this makes sense....
I have uploaded a clip here http://www.frederiksbergteater.dk/~dvd/zigzag.mpg (clip removed)
Pay attention to the guy with the beard's right arm and the contrast with the light wall in the beginning of the clip.
This issue does not exist when viewing the footage in VegasPro. I am rendering to DVD Architect PAL Widescreen video stream and when I view the output - either in VLC Media Player or previewing the created DVD in DVD Architect Pro the problem is there.
I suspect I have messed up some setting in Vegas, but who knows?
Any hint is highly appreciated![]()
Results 1 to 9 of 9
This looks like a screwed up interlace resize
I'm going to guess that you disabled deinterlace in the project settings. It's counterintuitive, but it's required to be on (either blend or interpolate) for vegas to do a proper interlace resize.
Try it out on a small sample -
Thanks poisondeathray,
Changing deinterlace to interpolate or blend improves it significantly
. However, it is not all gone - my other project settings are
pixel format: 8 bit, Motion blur type: Gaussian, Field order: upper field first, Pixel aspect: 1,000 (square), frame rate: 25 pal.
Any recommendations for change ?
deinterlace=none: http://www.frederiksbergteater.dk/~dvd/none.mpg
deinterlace=blend: http://www.frederiksbergteater.dk/~dvd/blend.mpg -
What sort of footage did you shoot ? 1080i50 ? if so , you should use that template. All your project settings look to be in order
But what where your export settings? Can you post another video sample with the new settings but "its not all gone" artifacts? You can post it directly here if <30MB
HD is always upper field first, so I would leave the field order. A reversed field order issue would cause jerky fwd/bwk playback, not these artifactsTry changing the field order. -
I used the match media settings in the VegasPro "new project" window. The footage is "HD 1080-50i (1920x1080; 25,000 fps)"
The export (I use the "render as" in VegasPro) settings are MPEG-2,
Audio: None
Video: 25 fps; 720x576
Use this setting to create a PAL video-only MPEG-2 file compatible with DVD Architect.
I have linked to two samples in post #3, but also attached here (called none.mpg and blend.mpg). Edit. The upload failed- -
Oh, I see what nic2k4 was getting at.. the export is BFF (bottom field first). You did a field order swap. Not sure if that will account for the difference. I would stick to UFF (top field or upper field first), since your source was UFF. You can access that in the settings DVD PAL Widescreen template, push the custom button, video tab, field order. Personally I would also checkmark stretch video to fill output frame size (do not letterbox)
NLE's are known for doing lower quality interlace resizes. You can control it better by using avisynth methods, but it's a bit complicated if you're not already familiar with avisynth basics -
Thanks to both of you, will try this out tomorrow, have to get some sleep now.
Ok, tried exporting with UFF as suggested, it is slightly better although it is hard to tell. It will possibly become more evident when playing on a DVD or DB. Will do some research alson on avisync also.
Thanks once again
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Is there something better than DVD Architect 5 to use with Vegas Pro?
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 12th Dec 2010, 21:46 -
Anyone know how I can buy the "Pro" ver of Sony's DVD Architect ?
By WBFAir in forum Authoring (DVD)Replies: 3Last Post: 6th Jul 2010, 15:02 -
sony dvd architect ?
By Deter in forum Authoring (DVD)Replies: 7Last Post: 26th Jan 2010, 18:31 -
Sony DVD Architect Pro 5.0b No Audio Stream
By petersm2 in forum Authoring (DVD)Replies: 8Last Post: 4th Jun 2009, 22:20
