  1. I am 100% sure I correctly ripped the DVD. I ran the ripped DVD through SubRip and OCRed automatically and manually all the subs. When I click on the little save icon it doesnt open a window to save it just goes to the part where I can choose the language, font and font size. But instead of the save button there is only a Done button. Why is this? What can I do to fix it?
  2. Yeah, I have the problem myself. There's a workaround to it and that's to open VobSubs (IDX/SUB) instead, rather than the VOBs or the IFO. First extract the VobSubs using VobSub Configure (comes included with the VobSub package). When done open the VobSubs in SubRip and OCR. You'll then be able to save your work.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    It is kind of weird, but i have never had a problem.
    I did a dvd a couple of days ago and just did one today with subrip.
    After choosing the "FILE" - "save as" another little button pops up on the right hand side, "SAVE", and just click it to save it where you want.
  4. Originally Posted by manono View Post
    VobSub configure only lets me open sub/idx files. but i need to extract them...
  5. Originally Posted by diamondback View Post
    It also opens IFOs. Use the drop down box.
  6. Originally Posted by manono View Post
    ok did that. tried it and now I get an indexing failed error
  7. Don't know. Maybe try VSRip.
    Aug 2005
    Holland
    In SubRip, when you've done the OCR, click here:
Name:	2010-06-13 15-38-16.jpg
    .... then, when this screen appears, click here:
Name:	2010-06-13 15-39-16.jpg
    Hope this helps...
