Hi-
Someone gave me a DVD of my band's performance. When I tried to watch it I was unable to view it on my TV's dvd player so I popped it into my PC. That failed too, giving me the message "Windows Media Player cannot play the DVD. The disc was created in a manner the player does not support". I'd like to view this but cannot seem to find a (cheap or free) software that will enable me to do this. I read that Daniusoft can import HD video and convert it, but it will not recognize the files in the HVDVD_TS folder. What can I do to view this?
Thanks in advance for any help that anyone can provide.
Try the free VLC player. It has all the usual codecs included.
http://www.kiva.org/about -
Ed-
Thanks so much. That worked like a charm! Can you tell me if there is a convenient way to take the video and convert it into a format that I can import into Windows Live Media so I can make youtube clips from it?
Thanks again. Your suggestion to use VLC was excellent! I really appreciate it.
Rich -
I'd need to know what format (container and codec) the video is.
Can you post a short sample of the video?
Otherwise, VLC can analyze while playing. See "Media Information" under Tools and cap the result screens.
A second way is import the file into Mediainfo software. Also a free download. Then post the result.Recommends: Kiva.org - Loans that change lives.
Thanks again.
Here's what I found under the VLC tools/media information/codec details screen:
Stream 0
type: video
codec:mpgv
resolution:720x480
display resolution:720x480
frame rate:29.970029
Stream 1
Type: audio codec:a52
Channels:Stereo
sample rate:48000 Hz
Bitrate: 192 kb/s
HVDVD_TS/HV001TO1.EVO
Please let me know if this is the information you need or if I need to look elsewhere and thanks again for your valuable time and advice. Its very much appreciated.
Rich
Converting HVDVD_TS folder to Blu Ray dISC
By mnproducoes in forum MacReplies: 2Last Post: 11th Aug 2009, 05:53 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
HVDVD_TS & Co., how to make it viewable?
By moerl in forum DVD RippingReplies: 2Last Post: 15th Dec 2007, 17:59
