An ExpressCard34 USB 3.0 card and drive can work on MacBookPros with this slot when the machine is natively Windows7 (i.e.via Bootcamp, not as a VM machine within a virtualisation software running on MacOS) with at least a significant speed advantage over USB 2.0
Start your read from:
"I used the PC Card on a MacBook Pro running BootCamp with Windows 7 64 Bit Home Edition"
http://www.bonafidereviews.com/review-of-blackarmor-ps-110-usb-3-0-performance-kit/
This would indicate that the hardware on a MacBookPro would support an ExpressCard34 USB3 expansion card and harddrive since this review states this when the machine is running Windows7 natively i.e. on Bootcamp.
So any incompatibility of using such a setup with a Mac on OSX is purely software, i.e. OSX does not have the drivers.
Comments?
Results 1 to 1 of 1
video to usb capture works perfectly at night but crazy during the day
By ddhandm in forum Capturing and VCRReplies: 10Last Post: 9th Aug 2011, 16:05 -
ExpressCard / 34 slot vs Firewire 800
By Sjogogo in forum MacReplies: 4Last Post: 6th Dec 2010, 00:54 -
Has anyone tried using a Panasonic UJ-232A or UJ-242A in a MB/MBP unibody?
By dmblum in forum MacReplies: 4Last Post: 15th Aug 2010, 14:14 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
Anyone know how Windows folder VIEWS works?
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 26th Oct 2009, 11:52
